All Tayda pre-drilled, powder coated enclosures out of stock
RICHB555
I noticed that all Tayda pre-drilled, powder coated enclosures are now out of stock. I emailed Tayda, and Hugo advised I use the Drilling/UV printing service. I’ll give it a try, but so much easier being able to just order non-custom pre-drilled painted enclosures instead of using the new service. Yeah I know - i’m whining.
Man this is a real downer. Its a couple bucks cheaper per enclosure to get the pre drilled va drill service. Probably why not available now. Funny i was just going to order a bunch of ore drilled too.
Bummer to lose the cheaper option. Although, it seemed like the order progress was no different from using the drill template system.
Stupid question time: is there a single source for all the various PPCB drill templates? I think I have maybe half of them. It can be an adventure tracking down a new one. Plus, I can't shake the fear that I may have altered the ones I have in my dashboard.
I haven't had a ton of time to build but I got a special request for a pedal so I went to order parts and saw this and came right here haha. It was the final push I needed to get the actual drill pattern I wanted with a larger DC jack hole for my preferred style. I'm just happy the cheaper shipping option was back.
I think it would be more beneficial/easier to have a list of ones that aren't standardized. Most everything confirms to the points on the PPCB drill guide in the store.
I bought a few predrilled ones ~1.5-2 years ago and for whatever reason, the circuits I intended to use them on all didn't align.
Just to update that all the PedalPCB enclosures are still listed as Out of Stock. Bummer, I hadn’t seen this thread or been shopping for parts lately so I had missed this.
I’ve only used the drill service less than a handful of times and have bought predrilled less than that… I have an 8” harbor freight drill press set up in my garage with a set of drill bits that are the sizes needed for all holes… takes me all of 5 minutes to drill my holes in a powdercoated tayda enclosure.. I have the drill press setup inside a mortar mixing tub and it catches 99% of drill shavings… hit it with the shop vac every once in a while when I feel like cleaning up a bit 🤣
