sorry man old post! I am looking to do something similar for an amp chassis.Decided to give a face plate a go. Turned out pretty well (besides being lame at naming pedals). It's a Sanguine Distortion (Revv G4). I have a couple extra. DM if you want one. Thanks to Szukalski for making the templates available.View attachment 61170
You can find a couple of DipTrace templates in the link:sorry man old post! I am looking to do something similar for an amp chassis.
Main questions - i assume they pre drilled the holes for you? or did you drill the holes yourself ?
if pre drilled - what mm size did you use for your pots and spst (if you remember?)
Thanks man. good info. Yeah the chassis im using is 254 x 51 so should work. I am just working out whether i buy an aluminium strip and use UV printing or try something different with these PCBS. Thanks for the measurements - that looks right to me, interestingly some of the amp chasiss pre drilled seem to be a tad larger - i cant work out why. I would have thought most pots are pretty uniform at 6.35mm and not sure why you would need bigger than 7mm. Evatco sells the tweed chassis with 8.5mm pot holes.You can find a couple of DipTrace templates in the link:
sheepylove-diptrace/faceplates at main · szukalski/sheepylove-diptrace
Diptrace library for building PCBs. Contribute to szukalski/sheepylove-diptrace development by creating an account on GitHub.github.com
tldr; 7mm for pots, 6.4mm for toggle switches.
They come pre-drilled. The only challenge you'll have for an amp chassis is the max size, 670x600mm at JLCPCB. Hate to think of shipping costs at that size!
The pot shaft is 6.35mm but there is a bit covering the shaft as well. Check the data sheet from the manufacturer. 7mm is pretty tight and doesn't give much leeway for wayward drilling.Thanks man. good info. Yeah the chassis im using is 254 x 51 so should work. I am just working out whether i buy an aluminium strip and use UV printing or try something different with these PCBS. Thanks for the measurements - that looks right to me, interestingly some of the amp chasiss pre drilled seem to be a tad larger - i cant work out why. I would have thought most pots are pretty uniform at 6.35mm and not sure why you would need bigger than 7mm. Evatco sells the tweed chassis with 8.5mm pot holes.
Thanks Man - its just a micro deluxe so reasonably small in terms of controls etc but a good idea. Have looked up a few PCB, acrylic/plastic options as well as the original option of getting a strip of aluminium from somewhere and just UV printing.You could break up the amp's controls into sections for smaller faceplates rather than having one big one...
thank you.I can vouch for Sandy's work, she's great!
