I'm looking for the schematic for the Dielectric Boost. I'd like to adapt a smaller board like a Je Taime etc to use this circuit in a smaller enclosure like a 1590B. Thank you
Je T'aime is your best and closest match.
Couple other choices:
The Amentum Boost as second choice, third choice would be the Aft Preamp.
Both are EQD one-transistor builds.
The Amentum would be easiest of the two alternativees to Je T'Aime, swapping out the emitter resistor for a switch loaded with the Lovepuddle emitter-Tchullery.
The Aft would be the choice if you want to add some features, such as the Aft's input cap switch.
Really though, easy enough, Je T'aime has all the necessary bits already in play...
Change Je T'aime's R5 to 680Ω and reroute from emitter to GND.
Sneak in a switch at C3 (mounting C3 to the switch) and follow the values in the schematic below or from the Dielectric PCB...
Dielectric PCB w: Je T'aime REFDES ADDED.png
Hi guys,
I'm hunting for the following build documents:
Souldrive - if the silk screen is accurate I could maybe order components off that, I'm assuming it's a 125b enclosure, can probably use a similar drill template.
Double pendulum - more info the better here.
ADHD - I ordered a PCB and the new improved bypass module. Is it safe to use the old documents for parts order? Haven't seen the PCBs yet so I haven't worked out how the bypass module works yet. Is it also still a 125b, I can probably use another drill template that's similar and modify it if need be.
Thanks.
Hello, I am wondering if the schematic for the Jump Drive (LPD sixty8) will be posted anytime soon? Last revision was 2022. Thank you!
I think this may be what you want:
