3 pedals in 1 Plus 8 Clipping & 8 Bandwidth options!
Mods: Battery & Stereo Input Jack.
Updated last message!.ah. Thanks for that.
With the Battery option, The 3 LED's need to be drilled inline with the Led's on the PCB.For those who want the Battery option, this is what used under the Battery.
The wires are longer & pass through the Middle to be soldered from the back side of the Centre Footswitch.
It is cut to the size of the Battery.
I used a 6mm Adhesive back Sponge on the Back Plate around 10mm larger in Width & Length as it forms a impression into the Foam.
It will not move once the Screws are in place.
I buy the Adhesive back foam in 400mm x 400mm Sheets from a local Foam & Rubber supplies shop.
Brass Sleeve :This is what I use if if Splined Knobs are not available. Make sure the piece of Cable tie is a firm fit, this is to stop snapping the spline tangs off.
For the 1P8T Rotary pots, the splined shaft is solid plastic so no Slit support is required. A 1/4'' Knob fits real nice with the sleeve in place
Mine are from WD Music products.
Cheers music6000
It now has Independent Boost thanks to the Man, ''PedalPCB''You could wire it up so the boost is independent. I'll take a look at the schematic and draw up a diagram.
How do you do the graphics? Is that a decal? Looks great!3 pedals in 1 Plus 8 Clipping & 8 Bandwidth options!
A4 Clear Gloss Sheet with Adhesive Back for Inkjet Printers.How do you do the graphics? Is that a decal? Looks great!
