Taqueria Overdrive PCB - Available Now!
As I understand it, normally the drain and source (D and S) are interchangeable. So you really just need to make sure your gate (G) is lined up right, and you should be good. The gate is the one on the single connection side.
If you look close at the traces on the PCB and your adapter board, you should be able to see what's connected to what.
Double-check me, but I'm seeing them as highlighted below in which case, I think you've got it the right way.
thanks for your help, i tested the board without FS and it is working, great !
Now i am confused about the final connections between main PCB / breakout board and IN/OUT jacks.
This what i did, but now i don't know what to do with the Jacks IN & OUT wires....(i connected in gnd sw out from the main pcb to the same on teh breakout board) so i guess i'm wrong.
Just go purple next to purple and orange next to orange on the daughterboard and you should be good
So I just ordered the Taqueria PCB and have a question about the biasing. When the Bias switch is up, am I biasing Trim1A, Trim2A, and Trim3A to the Tacobolt voltages, and then when the switch is down, biasing the Bs to Superbolt voltages? Still learning so I'm trying to understand.
Correct, except the opposite. Switch Down adjusts Trim 1-3A (Left), Switch Up adjusts Trim 1-3B (Right).
It's up to you how you set the bias, you can put the "Taco Bolt" bias settings in whichever position you want.... or your own bias settings in both positions.
Thank you! Makes sense.
I first set mine to the published Taco settings but I kept adjusting the trimmers until I found voltages that work better with my rig. I encourage you to tweak those suckers till you're happy.
I really love this pedal, it's got so much range. Enoy!
