Chuck D. Bones
Circuit Wizard
This Overdrive is heavily based on the BJFe Honey Beest, a Honey Bee with a JFET booster up front. It was a collaborative effort with HamishR. In his honor, I've cracked a tuber of Foster's Lager (yeah, I know, it's that wallaby-piss export stuff). HamishR had been advocating his modified version of the BJFe Model G; he sent me a copy of the schematics for that and the Honey Beest. I finally got around to breadboarding his Model the G and liked it immensely. It's a fairly mild medium-gain overdrive with a nice fat vintage tube amp sound. When I stuck on the Honey Beest's JFET boost up front, it took on a whole new personality. The PRE-GAIN controls the booster gain, from 6dB to 28dB. Dialed-down, it's very close to the Model the G tone. Crank it up and it roars. PRE-GAIN was modded from the Honey Beest for more range. It crackles a bit when turned. The BASS & DRIVE controls are pretty much unchanged from the Honey Beest. Turn the BASS down with humbuckers, up with single-coils. We wanted more range out of the TREBLE control, so it was rewired as both a boost and a cut. The boost side of rotation is really more of a Mid Boost, but that's ok, it sounds good. I used MPF4393 FETs, but anything with Vp between -1.5V and -2V will work (J201s need not apply). Like the initial design, the BA482 diodes were imported from Oz. They have virtually the same V-I curve as the gate-source junction on a 2N5952. At full-tilt, this sucker will push all three stages into saturation. Or turn PRE-GAIN down to zero and pull back on DRIVE for a mild breakup. Got some TS tones in there as well. In keeping with my potent potables theme, I named this one The Mojito. Cool, smooth and not too sweet, not too fizzy. Vero layout available on request. Check the date code on the vintage RCA CA3130. That IC was manufactured in March 1977.
