Talked it over with Chuck and I'm going to add the pre-gain foot switch to the layout for a 1590bb box. Chuck also gave me a workaround to use a 50KC pot instead of the now-hard-to-find 25KC.
Fingers crossed, should have those in a few weeks.
Sweet! I’m making an SMD/through hole mash up version haha
I prefer SMD for semis, but the only SMD pads on my layout will be for the JFETs, which will also have a TH footprint so either SMD or TH JFETs can be soldered directly to the PCB.
It will also be compatible with the PedalPCB footswitch PCBs.
For real estate purposes, 1590BB standing upright would be the best option :Talked it over with Chuck and I'm going to add the pre-gain foot switch to the layout for a 1590bb box. Chuck also gave me a workaround to use a 50KC pot instead of the now-hard-to-find 25KC.
are you looking at a pre-gain bypass of the JFET with the footswitch? or just switching to a unity setting?
also -- how different is the feel of the pre-gain pot if you use a linear taper 25K? not enough control for the most saturated part of the rotation?
This matches the PedalPCB Arkaim Fuzz layout minus Toggle switch!
I only see 6 links in the vero for this project unless there are 2 connections on 10 D. Is it 6 links or 7?Oh yeah - I'd love one!
I guess I should post my layout because its better than Chuck's.I have also changed a few bits here and there to make it sound very, very close to my Model The G if the Pregain knob is on zero. So you almost have two pedals in one - a G if Pregain is off and then wind in some Pregain for an increasing powerful distortion. I'm a big fan of touch-sensitive lowish gain overdrives, and that's what this is before you touch the Pregain. It's unusual to me to have a distortion level pedal which works as well as this one does at lower gain. But then I'm biased.
I'm kinda torn... I love the extra gain stage but keep finding myself turning the Pregain right down, in which case I may as well just use my regular G pedal - which is my favourite OD right now - and keep things simple. I think being able to footswitch the Pregain in and out may be the answer.
I needed Chuck's help to get the G to where it was as good as it can be so was surprised when Chuck said he had built one and liked it only to find he had of course added another gain stage!
So I think I'll stick with my G pedal until I can get the footswitch worked out. Having a pedal like the G with Chuck's extra gain stage of the Mojito on a separate switch would be perfect.
This Overdrive is heavily based on the BJFe Honey Beest, a Honey Bee with a JFET booster up front. It was a collaborative effort with HamishR. In his honor, I've cracked a tuber of Foster's Lager (yeah, I know, it's that wallaby-piss export stuff). HamishR had been advocating his modified version of the BJFe Model G; he sent me a copy of the schematics for that and the Honey Beest. I finally got around to breadboarding his Model the G and liked it immensely. It's a fairly mild medium-gain overdrive with a nice fat vintage tube amp sound. When I stuck on the Honey Beest's JFET boost up front, it took on a whole new personality. The PRE-GAIN controls the booster gain, from 6dB to 28dB. Dialed-down, it's very close to the Model the G tone. Crank it up and it roars. PRE-GAIN was modded from the Honey Beest for more range. It crackles a bit when turned. The BASS & DRIVE controls are pretty much unchanged from the Honey Beest. Turn the BASS down with humbuckers, up with single-coils. We wanted more range out of the TREBLE control, so it was rewired as both a boost and a cut. The boost side of rotation is really more of a Mid Boost, but that's ok, it sounds good. I used MPF4393 FETs, but anything with Vp between -1.5V and -2V will work (J201s need not apply). Like the initial design, the BA482 diodes were imported from Oz. They have virtually the same V-I curve as the gate-source junction on a 2N5952. At full-tilt, this sucker will push all three stages into saturation. Or turn PRE-GAIN down to zero and pull back on DRIVE for a mild breakup. Got some TS tones in there as well. In keeping with my potent potables theme, I named this one The Mojito. Cool, smooth and not too sweet, not too fizzy. Vero layout available on request. Check the date code on the vintage RCA CA3130. That IC was manufactured in March 1977.
