Dirt_diggler
I build a KOT clone today and it sounds absolutely beautiful..... only with Guts outside the enclosure.
I tried many different scenarios and have determined that the pedal is shorting out when the OUTPUT jack touches or is tightened into the enclosure. It also seems to affect the second side (left side) tone knob. I've reflowed both and even changed the jack to no avail. I can tighten down all of the pots and leave the output jack out of the enclosure and it works beautiful. It is strictly when the output jack is tightened into the enclosure. The backplate is never on and nothing is touching the jack lugs. it happens when the threads of the output jack touch the enclosure. Not sure where the grounding can be but what do you recommend?
Schematic can be found under the build doc pdf on this page.
rullywow.com
![rullywow.com](https://rullywow.com/wp-content/uploads/2016/07/3D-PCB-no-components.png)
Queen of Bone 2 (King of Tone™ 18v clone) PCB
Inspired by the King of Tone™ dual Marshall Bluesbreaker circuit – but with 18v charge pump onboard. Two overdrives in one pedal – great on their own or stacked. Uses standard 9VDC an…
![rullywow.com](https://rullywow.com/wp-content/uploads/2018/01/cropped-square-rullywow-pcb-logo-512x512-1-100x100.png)
