PedalPCB Median Compressor
Mikeydubsj
Hey guys, I am building a few Median Compressors, and I just finished my first one and had a few questions as I can't get it to work.
I've been building pedals for a few years, and have learned a lot, but this is my first compressor. There's a few things in this build that I haven't encountered yet. So I apologize if this i'm just missing something stupid, but here is what I've got.
*Main Issue
TR1 10K Trimmer potentiometer, 3362P type. The PCB itself has a 5 hole spot for this pot, however the only 3362 types of pots i've seen only have 3 poles. Am I wrong in using this? Is there a different pot that I should be using? If anyone has questions that would be amazing.
IC replacements
I've seen other people using the TL072CP chips as opposed to the OP1678. (I had originally bought the OP1678 and the through hole adapter, but the ICs I bought weren't the right size. I will update that in the future. But will this still work with the TL072CP?
Q1 & Q2
When installing, I used a socket for the transistors for easy access to reversing them in case I got it wrong. Is this a bad practice? I just figured it would make things easier in case I made a mistake.
I've been reading up on how to bias the transistors, but i'm not sure i'm even to that point yet since I can't get any audio out of this circuit. Even if I roll the TR1 from one extreme to the other, I get no signal.
Other than that, I linked a picture of my build in here as well. Any help would be greatly appreciated!
Trimmer is good - that layout accommodates two different pin configurations.
I don't know about the TL072s personally, but if the word on the street is those work, they probably work.
Transistor sockets are a bummer because eventually after some number of stomps, the trans like to work themselves loose and start causing problems. In this case it was maybe a good move, since it looks like yours are upside down.
You’re fine using that. The 5 holes are there to accommodate different sized trimmers.
It looks like it would based on the Datasheet. It will be noisier, but might be fine.
I used to socket my transistors early on. Eventually I picked up a tester and these days I usually solder them directly in. Using sockets isn’t “wrong”, but it can lead to connectivity issues if the pedal gets jostled around.
As i have been told when I post a build report with transistors in sockets, once you know everything is working, you can add a bit of solder to keep them in place.
On some fuzz pedals I have transistors in sockets so I can experiment with different types, hfe, etc. When I can finally make a decision I will add some solder lol!
I verified the prototype with TL072s before my 1678's arrived.
The bottom left TL072 in your photo does not look genuine.
How can you tell? These are actually ones I've had sitting around in other pedals. Once I found out the original ICs I bought weren't the right size, I went and scrapped these out of old builds.
I'm still not getting any audio out of my pedal. Last night I went and checked every solder joint in the schematic and everything should be working, but it's not. So I was guessing either Q1 and Q2 are in the wrong way, or they were bad. I had extras so I did try out other ones and in both variations (just in case). But it still didn't work.
So now i'm thinking it could be the TL072 that might not be working. Maybe all of them? or could it be just that one?
Have you adjusted the bias trimmer to measure 1.875V on Q1? It may be that your JFETs are out of range. Try searching the forum for related threads. There’s a lot of info available on this build.
“The original has a test point on the Drain of Q1 that measured 1.875VDC. You could start there, or take a look at the biasing instructions for an Orange Squeezer compressor.”
I tried doing this, but the highest reading I could get was .49VDC.
