Red Big Muff sounds bad
Erik S
In honor of the big red big muff everyone’s talking about, I thought I’d throw this Liquid Crystal Fuzz together in a red box.
Everything works, but it sounds bad.
It’s doing some weird saggy, bloomy, sputtery stuff that I’m pretty sure isn’t right.
I pulled it back out of the box and did a component check and a careful solder inspection and everything looks okay there.
I got 100 of these cool blue-face Motorola 2n3904s from the small bear “parts for a penny” sale, and it’s the first time I tried em. So I’m a little irrationally suspicious of those.
Right now I’m thinking I’ll pull the 4 transistors, see if any of them test weird and try new ones.
Any of you muff wizards want to recommend ideal transistor specs while I’ve got the tester out?
Well, my tester says they’re all transistors, so none are totally broken I guess.
hFE measurements:
Q1 - 229
Q2 - 196
Q3 - 136
Q4 (2n5089) - 499
Those 2n3904s are probably on the low side of in spec if I’m reading the data sheet right, but I just tested a random handful of tayda ones and they’re all right around 240, so unless someone has any more specific advice I think I’ll throw those in and see what happens.
Well, who would have guessed that shotgun-replacing components with no evidence they’re bad wasn’t going to fix the problem??
Put it all back together and it still sounds weird.
I think this is supposed to be one of those eqd circuits where they cloned somebody’s broken pedal that they liked, so maybe it’s supposed to sound bad?
I did go listen to some of the demo sounds on the eqd site though, and that made me think there was something wrong with mine.
Maybe I’ll try and record a demo of the weirdness at some point. I think I’m done for the day though.
Well id rule your soldering out of the equation.. From what I can see it's freakin nice and not slathered with flux...
Thanks! I’m hit or miss with my pcb cleaning, but I happened to clean that one pretty good.
Still haven’t found anything obvious wrong with it. I have a second one of these boards. I might just build that out and see what it sounds like.
It does sound a little bit sputtery to me, but I assume yours is even worse?
A couple demos I checked:
Nothing looks wrong from what I could see, but I only checked R4-5, R10-11 and R15-16, all the orientations and easy stuff like that. Soldering looks great, so my money is on a bad component or a broken trace somewhere or something like that.
Thanks for those. Those were both good demos.
Something I failed to mention was that I’ve mostly been testing the pedal on bass since that’s where I was hoping to use it. I did plug a guitar into it for a few seconds and it sounded much more normal.
I used this site to help guide my changes. From my memory, the transistors do not influence the sound as much as the other components.
Great page! I didn’t do very deep research, but I did find that site in a @Feral Feline post and skimmed it. Seems like if I want to stop taking shortcuts and put the time in, all the answers are there.
Try putting a 2N3904 in Q4 and see if you like that better.
I’ll give that a shot!
I do like that better! It still gets a tiny bit unruly at max sustain on bass but in a nice way to my ears. It doesn’t sound broken anymore.
I’m a little worried that maybe it was cool before, and I just wasn’t cool enough to like it, but that’s a me problem.
I've got a quote from Kit Rae that basically amounts to something like all the best-sounding muffs he's come across are much more low-gain than you'd think (hFE of transistors, specifically).
I'm not on my own computer at the moment so can't dig out the quote, maybe later I'll remember to look for it.
PS: Here 'tis, @Erik S :
"When I pulled all four FS36999 transistors from an exceptional sounding 1973 Big Muff and measured the hFE I found it ranged from 164 to 204 (Q1: 164, Q2: 204, Q3: 183, Q4: 161)." — Kit Rae
Additionally...
When Nicholas Kula posted in The Tone Report a DIY build of the mystery Muff (no, not the latest dual op-amp mystery JHS gate-kept Red Barren [sic]), the red-October 15th 1975 red-letter schematic, he mentioned this:
"...it begs noting that I was perusing the DIY forums and I came across an intriguing post: A user had gotten access to a vintage Muff (FS36999 transistors) and was able to remove and measure the devices out of circuit. The results were astounding: The transistors all measured between 160 and 200 hFe—noteworthy because most modern Muff clones (including the current Electro-Harmonix release) use 2n5088 or 2n5089 transistors, which boast 300 hFe at the absolute minimum. Clearly, this is a significant discovery, and a rule I will recommend when building this pedal. Obviously, any NPN transistor of higher gain will work (and one may certainly like others better) but they will not be 'vintage-spec.'" — Nicholas Kula
