mdc
I have a bag of these DC jacks that were sent with the incorrect hex nuts. Just curious if anyone happens to know of a source for the proper ones - I believe they're 12.7x1.0. They don't seem to be available at my normal spots.
In my experience Tayda will not send you replacements. They will just credit you and you have to order again, with the new insane shipping charges.Have you tried messaging tayda? That’s probably the easiest route.
They slip over the barrel completely, unfortunately. Good point though - I should make sure the barrels aren't actually M12/metric or something like that.Those nuts in my opinion are always quite not the perfect size, but will thighten ok... how bad are they ?
These DC jacks are also available in a smaller thread & you have to drill a smaller hole as 1/2'' is to big & the jack falls through!!!I have a bag of these DC jacks that were sent with the incorrect hex nuts. Just curious if anyone happens to know of a source for the proper ones - I believe they're 12.7x1.0. They don't seem to be available at my normal spots.
If you can figure out the thread and pitch, can get a bad of whatever color from AliExpress shipped for $3 or so. I think most m12 we use is 1.75 pitch but may be wrong. See if there's a datasheet on tayda.
Wouldn’t the 1.0 on that data sheet be the thread pitch?[12.7 x 1.0] is all we have from the datasheet.
thread pitch appears unspecified.
yeah, i was foolish enough to try them out, before realizing the figures above. (12.0mm isn't gonna fit on 12.7mm, or whatever figure it really is)
thanks @Erik S !
so as mentioned above, M12.7 doesn't really come up or exist (it appears).
perhaps the real size is an imperial measurement? what should i be looking for? (imperial confounds me)
