My mother had a 68' convertible for the better part of 40 years same color... I have worked on that car hundreds and hundreds of hours over the years. I few years ago I was keeping it at my house in Georgia while they had some home reno done for months. After almost a year they sent me the title and said to keep it..lol. I cruised around here and there for a couple years and decided it's not an aircooled Volkswagen and told my Mom she could have it back. They wanted me to sell it and split the $$... I'm just outside Atlanta and the guy who ended up buying the car turned out to live 5 miles from my parents south of Birmingham, Al... lol They see him all the time driving.Trying to do some tidying up to make her roadworthy. It’s all little piddly stuff but important. I scored a rear view mirror on eBay and installed it today. I have hardware coming to install the old door panels until I pull the trigger one new ones (expensive). I’m gonna get some new tires to throw on it just to drive around on until I settle on new wheels and tires. Seat covers are on the agenda too. In case you’re curious it’s a 75. All new crate motor and transmission. She runs like a champ she just needs finishing. My dad is getting older and said he doesn’t have time or really care about finishing it anymore so he went ahead and gave it to me. I fixed the hood the other day so it latches. Like I said, little stuff.
That’s been my experience with hand-soldering smd. I had better results with a chisel tip than a tiny pointy tip.Plus I think I switched to too pointy of a tip and it couldn't retain/transfer heat well even for this.
I did, so far anyway. Other than the inductor. I tried other values in certain spots but I generally like it in stock form. Changing the ranges center frequency is the big one for me.@Guardians of the analog
Did you keep the rest of the circuit stock?
I run a buffer right after it and don't notice any real issues. I actually run a couple buffers on my board and use short cable runs.Do you tend to keep the stock parallel bypass? I tend to find that bypass to suck too much toan.
Ok, I did some very critical listening with the amp clean and it was super obvious. As soon as I took the wah out of the equation it was fuller and all the frequencies were present. Will be doing true bypass mod.Do you tend to keep the stock parallel bypass? I tend to find that bypass to suck too much toan.
Little Bastard 30@vigilante398 Peacemaker? Or a different model? That front plate looks different than what I can recall off the top of my head.
I like to swap the input buffer with a JFET buffer like @Stickman393 does, I use the PPCB JFET buffer board as a guide.Ok, I did some very critical listening with the amp clean and it was super obvious. As soon as I took the wash out of the equation it was fuller and all the frequencies were present. Will be doing true bypass mod.
I'm actually thinking of doing the jfet input buffer AND true bypassI like to swap the input buffer with a JFET buffer like @Stickman393 does, I use the PPCB JFET buffer board as a guide.
