Any chance to get the build docs uploaded for Fordoble (The Dane)? I would like to order a kit for it on Musikding but they said they need the docs before they will put it up.
Musikding said the same thing about the Octarock Octave, even though I sent them the bill of materials I found on the forum.
Until the build doc gets uploaded you can use this parts list I made from the board photo (shows the part numbers). The only build notes I will do is to socket the op-amps and put socket pins in for the zener and germanium clipping diodes so I can experiment to see which ones sound the best. Fordoble Parts List Excel
Reactions: Thk
Whenever build docs for the micro boards do come around please make sure it tells us what size for us smd newbs!
I don't think 0402 was the right size. Lol I got the right size transistor and diode though.
I also saw a post a while back about wanting an option for presoldered smd utility things like this here microboost and the micro blend. I definitely second that idea lol.
Eyeballing those footprints, I'd say all of the passives are 0805. Here is an 0805 cap against the SOT-23 transistor - you can see
that the middle of the pads are pretty close to the same.
The diode is a SOD-123 (or 123F or 123FL, they're pretty equivalent in my experience)
Thank you! I'll probably tack the proper size components on to my next tayda order then.
The FUZZ REMAINS schematic is absent...
...Just sayin'.
I've started a visual trace from screen-grabs, as I don't have the PCB for a proper trace. May have to rectify that.
Hey Robert,
any chance of a schematic/build doc for the Quarry Fuzz, Silica Fuzz and Dual Big Muff??
Been waiting to purchase these, but would like a look at documentation first.
thanks
Hey Robert,
thanks
For the 2xmuff, just use the muffin build doc. Same refdes with A, B designators.
Silica components here:
Here's the parts list:
Potentiometers:
B1K
A250K
10K Trim
2x 20K Trim
Capacitors:
10n
22uf
47uf
1uf
Transistors:
4x 3904
Diodes:
5817
Resistors:
100K
1M
470R
33K
1K
4K7
Quarry is a TB MkII with an output buffer. Robert will.likely get to this one eventually. He's been wrapped up in a big home project and has some catch up to do.
BJT spec are here
I'll get a full parts list for you later today, but:
3 x MP39b
1 x TL072C
1 x TC1044SCPA
Q1
hFE=43 at Ic=5.00mA
Vbe=0.211V at Ib=1.00mA
Vbe=0.323V at Ib=5.00mA
VceSat=0.042V at Ic=5.0mA and Ib=1.00mA
IcLeak=0.039mA
Q2
hFE=64 at Ic=5.01mA
Vbe=0.215V at Ib=1.00mA
Vbe=0.317V at Ib=5.00mA
VceSat=0.040V at Ic=5.0mA and Ib=1.00mA
IcLeak=0.058mA
Q3
hFE=47 at Ic=5.01mA
Vbe=0.201V at Ib=1.00mA
VceSat=0.052V at Ic=5.0mA and Ib=1.00mA
IcLeak=0.105mA
