Missing Build Docs / Schematics
Any chance to get the build docs uploaded for Fordoble (The Dane)? I would like to order a kit for it on Musikding but they said they need the docs before they will put it up.
Musikding said the same thing about the Octarock Octave, even though I sent them the bill of materials I found on the forum.
Until the build doc gets uploaded you can use this parts list I made from the board photo (shows the part numbers). The only build notes I will do is to socket the op-amps and put socket pins in for the zener and germanium clipping diodes so I can experiment to see which ones sound the best. Fordoble Parts List Excel
Reactions: Thk
Whenever build docs for the micro boards do come around please make sure it tells us what size for us smd newbs!
I don't think 0402 was the right size. Lol I got the right size transistor and diode though.
I also saw a post a while back about wanting an option for presoldered smd utility things like this here microboost and the micro blend. I definitely second that idea lol.
Eyeballing those footprints, I'd say all of the passives are 0805. Here is an 0805 cap against the SOT-23 transistor - you can see
that the middle of the pads are pretty close to the same.
The diode is a SOD-123 (or 123F or 123FL, they're pretty equivalent in my experience)
Thank you! I'll probably tack the proper size components on to my next tayda order then.
