SWITCH-CRAFT (got any creative uses of switches?)
Does anyone have a schematic for a switcher to take a pedal out of an FX loop?
My use case is the HX FX- I want to have my gain pedals in the loops, but want to be able to run them stand-alone with a button press
GGG's Translocator should do the trick. SCHEMATIC PDF
Also check this out, all the deets are here:
I believe you want APPLICATION #5 ( 👈 link to PDF)
Close, but not quite what I'm wanting. I basically want to take the HX out of the chain, leaving only the dirt.
I feel like I've seen something that could do that previously (think it was used on a delay) but can't seem to find it on the googs
Well that changes everything... and maybe nothing. I still think the Translocator can do what you want, but you'd have to jump some jacks.
I beat my brains trying to come up with a solution, but as is often the case, it turned out to be much simpler than I initially thought.
I think it can be done with a 3PDT stomper — 2 poles for the switching and one for the A/B-indicator LED.
Here's a block diagram of sorts:
It's always quite possible I've missed something, such as having the HX LOOP SND loading down the guitar's pickups when bypassing the HX's input...
I'm certainly no rocket-appliancest, please point out whatever I did wrong.
I think you could potentially have some weird loading issues.
Also, any time based fx on the hx will bleed over. Might be cool as a tails option, but if you flip back to the HX, there's the reverb/delay from the last riff ...
I was thinking on this early today but couldn't gather my thoughts.
I think your want to switch the dirt in and out to amp too.
You could also do it with two poles by taking the dirt out to the amp. It would only bypass post fx loop effects, but that may be a good thing too.
So, one pole to switch dirt out to return/second switch
On pole to switch HXour/dirt out from previous pole.
Then you could still use tuner compressor etc at the HX and have an indicator.
I thought the idea was to get rid of the HX completely when running just dirt.
To include the HX Post-DIRT:
If you do get some loading, use a 4PDT instead of the 3PDT: 2 Poles for switching as per diagram above, 3rd pole to isolate the HX LOOP SND or wherever it's needed; last pole for LED channel-indicator.
PS:
@DGWVI
I don't see how there'd be any bleed-through now, with the 4PDT.
Awesome, thank you!
I need to clear the jobs on my bench, then I'll give this one a go. If needed, I'll throw a buffer in
PS:
@DGWVI
Yes, I'm wanting to completely remove the HX from the path (tails are fine, but I don't use delay or reverb anyway)
One last one for you @DGWVI:
This one almost entirely isolates the HX, save for the dirt hitting the return-loop of the HX — which could be eliminated if you go to a monster-toggle 4PDT that you can flick with your toe, downside being no LED indicator.
I look forward to seeing what you end up implementing (buffer etc).
Well, this sort of fits with the theme of the thread — unusual switchery-craft...
See gull, see gull scream, mimic seagull, mimic seagull screams... post some seagull memes...
DO IT! DO IT FOR JONATHAN LIVINGSTON!
On a much more prosaic level than electronically-backwards wah-gulls, and returning to the original theme of a repository for handy switch wirings, I always find that when I want to do a little series/parallel switching, I have to scout around for the wiring plan. So here's one:
Parallel-resistors switch was already covered, IIRC, but bears repeating...
The GRUBB-SWITCH:
Key items from that thread:
1650630307781-png.25558
Sub out the caps for resistors or clipping diodes or...
An old-thread came up on my recent-radar, so if you've run out of PedalPCB order-switcher boards,
you can still flip-flop the order of a combo build — just hand-wire up a 3PDT or 4PDT ...
EDIT: It has been brought to my attention, by the esteemed Jimilee, that hand-wiring instead of using breakout-3PDT-boards might be less prone to circuit-oscillations (due to breakout-boards' close-proximity of traces).
Even hand-wiring, I prefer to run the IN and OUT on opposite poles of a 3PDT with the centre-pole pulling LED-indication duties. Keeps those signals as far apart as possible, unlike the other bypass methods that shunt the bypass-LED to the third-pole.
Some XLR bypass toggle thingy...
Came across this old post today...
dp3t-type-1-dual-circuit-wiring-png.44584
Still hoping for some more crazy-switcheroo tadoo from all of you...
Don't forget, the title is Switch-craft, the arcane usage of switches, not to be confused with Switchcraft the brand, which is more involved with connectors than switches, really...
I wanted to add the following to the post quoted above, but thought it might fly under the radar.
The post above gives you A \ B / A>B (both circuits in the third toggle-position) while the following changes it up gives you both circuits in the middle toggle-position ie A \ A>B / B ...
The number of times I've blathered on about 2 x Order-Switchers, and given the numerous permutations of order-switchers I've made diagrams for — I was sure I must've previously draughted a diagram for the double order-switcher concept.
Apparently not, despite my addled mind's assertions I had...
Here you go, folks, mix up your A-B-Cs with your 1-2-3s!
So if you're doing a combo build, just sub in the PCBs for the send-return jackage above.
You could swap things around and have A&B revolving around C, too. Maybe I'll draught that next... BRB...
OKAY, here's the CBA Double Order-Switcher, and note that the available centre positions are indeed "different" than the ABC swapper above:
Really, though, there's no difference because you just need to work out which of the three circuits you want to revolve around the other two — where you place them in the enclosure, that order, is whatever makes the most sense to you as to what's doing what when the order toggles are being flipped, whether you want "C" first or not is arbitrary. You could swap circuit "C" above for the first diagram's "A" position and it's doing the same thing...
Hope that makes sense, it's clear as quicksand to me.
ABBOTT: "A before B and B after C, you see?"
COSTELLO: "If you're A and I'm C, I don't see who's B, the bat?"
ORDER UP!
You've been served.
Here's something I've been working on for a bi-amp project. I know @Feral Feline will like this
I am doing this to two 4x10 bass cabs to run a low passed signal through my bass head and a high passed signal through a guitar head, of which I picked up recently. I still need to build my LPF/HPF splitter and a new I/O pedalboard buffer to handle two separate signal chains.
LOWFREQ'N' AWERSUM!!!!
