Feral Feline
Does anyone have a schematic for a switcher to take a pedal out of an FX loop?
My use case is the HX FX- I want to have my gain pedals in the loops, but want to be able to run them stand-alone with a button press
Further to the above-mentioned GGG Translocator...
In the GGG documentation the LED-switching is done on SW1a. However, I've put the LED-switching on SW1d, and bumped the other poles over. If I'd kept to GGG's poles, then my SW1's lug numbers would've matched up as well.
Since I've already numbered everything and laid it all out, I'll ditch the GGG's switch-lug numbering and stick to my own numbering for that;
here's my version of the GGG layout:
Again, that perspective thing.
GGG has used the terms LOOP SEND (Jack 6) and LOOP RETURN (Jack 5) more or less as the main IN...
GGG's Translocator should do the trick. SCHEMATIC PDF
Also check this out, all the deets are here:
Effects Order Switcher: DIY Kit, Schematic & Wiring Diagram
Swap the order of two pedals with one stomp. Free schematic and wiring diagram for the Effects Order Switch Box; complete kit from General Guitar Gadgets.
generalguitargadgets.com
I believe you want APPLICATION #5 (
