yo, I was wondering if you knew how to go about adding an aux input to this circuit? would it just be a matter of wiring another jack to the headphone out jack? would I have to add resistors somehow?
Attached is a vero layout for a daughterboard I've used in the past. The pot (100k) is an input trim adjustment and can be internal or external depending on your application.
EDIT: IN is taken from the main instrument circuit path, the TRS connections are for the AUX input, and OUT goes to the input of the headphone amp circuit.
@benny_profane thanks for sharing this aux input daughterboard! Quick question, what orientation are the 100uf and the 10uf capacitors? And am I right in reading that the 0.1uf and 100nf capacitors are the same value?
It's faint in the color shading, but I think it is the 100uf with the negative pointed down on the layout, and the 10uf pointed up on the layout. But correct me if I'm wrong, thank you!
