mjh36
The designs in here look great, well done everyone. I'm preparing a file for printing, I noticed the instructions on the Tayda website say nothing about Roland swatches, do I still need to do that step?
Please double check with someone else because I haven't used the UV service yet, but they do mention it in their instructions:
"1- Create layer named "WHITE" , If you have anything on your artwork that needs to be printed in WHITE, please put that part of your artwork in to this layer. If you don't have anything in white then you can ignore this layer. Everything in WHITE layer must be painted with RDG_WHITE paint using ROLAND SWATCH, NOT normal white paint, it must be RDG_WHITE, when you use this paint whatever you paint will look greyish color instead of white, no worries, printer will still print it white, greyish color is just computer code to tell printer open white ink on those areas. You can import ROLAND SWATCH to your Adobe Illustrator using below link
Once you import it to your AI it will look like below image, you will need to use "RDG_WHITE" paint "
