Where can I find the BTDR-2H (long) IC called for in the BOM? This is for the IC2 component on the pcb. I checked small bear and tayda, to no avail. All I can seem to find are SMD reverb IC's. Thank you.
Top Quality Parts for Guitar Effects Pedals and DIY Music Devices. Knobs, Pots, Switches, Kits, LEDs, Enclosures, Jacks, Wire, Resistors, Capacitors, Semiconductors
The brick mounts to the back side of the pcb with the potentiometers. I personally prefer the Short Decay brick in this circuit. The Belton brick has built in modulation that is exacerbated by the longer decay times. I find the modulation less desirable. Also, the Short Decay brick is more spring reverb and less ambient chamber sounding. If that's your thing.
I got mine (medium) on sale from Amplified Parts, which is the same company as "Antique Electronic Supply" that Benny_Profane linked to with the URL "tubesandmore".
Really, it should just rebrand as one coherent company with a matching URL.
I got "Medium" because that's what the BOM from another PCB supplier said to get; Said "only", which at the time being green and very new to pedal-building, I believed it even though I immediately wanted to experiment and try the long. Same PCB supplier said you must keep the dual-gang pot a dual-gang... so when I get around to finally building the damn thing I'm going to experiment with separate pots.
Definitely will be getting a long and a short version of the brick in future, maybe a couple as there's some hacks over at MadBean to take out the modulation... dicey, might ruin your €x₱€₦$iv€ brick, not recommended if you've only the one brick.
I'll also be mucking around with extending the PT2399's delay times, modulation, tap-tempo...
On a bittersweet "note." I am making three of these in honor of a fallen friend. Two are going to his family. I ordered Long, Med, and Short. Thank you guys for the help!
