Value of the drain resistor depends on parameters of the particular jfet and other factors. Looks like 100k is a leftover from transfering tube amp schematics to jfets.About JFETs, is a JFET any good if it needs 100k drain resistor to be biased properly?
It depends. As a source follower (buffer) - yes. In a gain stage - sometimes.And are J201 and 2N5458 swappable?
I don't like smd's with adapters because they must be soldered and are not removable. And transistors don't like heat.
Thanks
Those look like quite useful LTSpice plots, how did you set up your command to step through 3 different transistor/resistor combinations?Value of the drain resistor depends on parameters of the particular jfet and other factors. Looks like 100k is a leftover from transfering tube amp schematics to jfets.
Below I attach screens from ltspice.
You can clearly see the difference between J201, 2N5457 and 2N5458 in terms of gain.
I only adjusted Rd value to get 4.5V on a drain of each transistor. Rs does not change (because people usualy adjust only Rd value. And often it's a trimmer).
Rd for J201 =34.3k
Rd for 2N457 =16k
Rd for 2N458 =11.95k
Rs = 3k
I use resistor leg cutoffs on my SMD adapter boards & they work great in sockets! Also never had a problem with SMD JFETs & heat, and I use a standard hand iron to solder them.I don't like smd's with adapters because they must be soldered and are not removable. And transistors don't like heat.
The schematic is likely in Chuck's Boneyard post on itMojito Deluxe Overdrive is still missing build docs and a schematic.
Thanks for these informations...Value of the drain resistor depends on parameters of the particular jfet and other factors. Looks like 100k is a leftover from transfering tube amp schematics to jfets.
Rd for J201 =34.3k
Rd for 2N457 =16k
Rs = 3k
Nope! Just a pic of his finished prototype.The schematic is likely in Chuck's Boneyard post on it
Nope! Just a pic of his finished prototype.![]()
Well, that definitely helps.Celebrating the Autumnal Equinox with another pedal - The Mojito
This Overdrive is heavily based on the BJFe Honey Beest, a Honey Bee with a JFET booster up front. It was a collaborative effort with HamishR. In his honor, I've cracked a tuber of Foster's Lager (yeah, I know, it's that wallaby-piss export stuff). HamishR had been advocating his modified...forum.pedalpcb.com
Is the Lo-Fi Machine PCB going to be available again?is the Lo-Fi Machine build doc available anywhere?
