Rosamp SLO 30 and Troubles
Northernguitars
Hello :)
I am new on the Board.
After some years of Pedals and Amp Restorstions I started my First Full Build.
Unfortunately i got some troubles with my SLO build.
The Problem is:
Without a Pedal in the Loop the Amp works Fine. Even with a Patch Cable only in the Loop it works without a Problem.
But if i put a Pedal in the Loop Everything that comes out of the speakers is annoying hum. Nothing Else, no Guitar Signal. It doesnt make any difference which Pedal i use… on the other Amps they all work Fine.
In the Rosamp Layout it looks like the bare Shield is connected to V4 Pin 7. that didnt make Sense to me so I connected the red wire like on the other Parts. Maybe here is the Problem?
When This Problem Happens I wont get Sound from the Amp Even if I restart it. It is only some whispering low Sound noticable.
I have to wait a few minutes, Plug and Unplug the Loop Jacks a few Times and then it works Like before.
Maybe you can help me out to find the mistake?
Otherwise i really Like how the Project went so far. In the past I have done some restorations to a Marshall 2204 from 1988 and a early Soldano Hot Rod 50 PLUS (which i still have.)
Please forgive me Language Mistakes, i am from Germany and so its a Little Challenge to Talk English.
Kind regards
Christian
Glad you got it fixed! If I remember correctly there are two or three spots where there is a small mistake with the shielded coaxial. Usually you would connect the actual cable to carry signal but and never the shielding in two spots.
Correct. A shielded cable  inside a piece of gear only needs the shield connected at one end. Connecting both ends can create a ground loop which is a source of noise.
Do not confuse this with external guitar/instrument cables which do need the shield connected at both ends.
Thank You!
Your Thread inspired me to Build it!
Do you remember which Knobs you bought? I think they look way better then the SLO Sifam Knobs
