Q3's collector voltage is -9v?!![]()
Hey Robert,
Any chance you could upload the build docs/schematics for Acrobat?
For being such a simple chip, it's soooo hard to represent the 4007 in a schematic. The most beautiful I've seen is the original MPF-1 schematic, but even that is unwieldy.
I do 'em like this, that about the same as your method?For being such a simple chip, it's soooo hard to represent the 4007 in a schematic. The most beautiful I've seen is the original MPF-1 schematic, but even that is unwieldy.
My lifehack is to use symbols for discreet mosfets and NOT gates, depending on how the 4007 is configured in circuit, and tack the appropriate pin numbers on the schematic
Thanks for the schem! Now I know why that B10kDG does what it does. Mods ahoy!
If you like how that one turned out, I could share it.Is there a drill template for the USB Pedal Power Converter?
Most Excellent! Thank good sir.If you like how that one turned out, I could share it.
Thread 'A powerful trio' https://forum.pedalpcb.com/threads/a-powerful-trio.21563/
Edit : you can now find it here
1590A Thread 'USB Power'
Here is the drill template I used for mine. Fell free to use.
Robert told me that if you use a 5mm Male standoff paired with a 20mm Female standoff (on opposite sides of the PCB) you don't need any mounting holes or hardware on the outside of the enclosure.
- Nic
- Forum: Tayda Electronics Drill Templates
