Missing Build Docs / Schematics
Any chance to get the build docs uploaded for Fordoble (The Dane)? I would like to order a kit for it on Musikding but they said they need the docs before they will put it up.
Musikding said the same thing about the Octarock Octave, even though I sent them the bill of materials I found on the forum.
Until the build doc gets uploaded you can use this parts list I made from the board photo (shows the part numbers). The only build notes I will do is to socket the op-amps and put socket pins in for the zener and germanium clipping diodes so I can experiment to see which ones sound the best. Fordoble Parts List Excel
  • Like
Reactions: Thk
Whenever build docs for the micro boards do come around please make sure it tells us what size for us smd newbs!
I don't think 0402 was the right size. Lol I got the right size transistor and diode though.
I also saw a post a while back about wanting an option for presoldered smd utility things like this here microboost and the micro blend. I definitely second that idea lol.
Eyeballing those footprints, I'd say all of the passives are 0805. Here is an 0805 cap against the SOT-23 transistor - you can see
that the middle of the pads are pretty close to the same.
The diode is a SOD-123 (or 123F or 123FL, they're pretty equivalent in my experience)
Thank you! I'll probably tack the proper size components on to my next tayda order then.
The FUZZ REMAINS schematic is absent...
...Just sayin'.
I've started a visual trace from screen-grabs, as I don't have the PCB for a proper trace. May have to rectify that.
