Probably a dumb question, but for boards like the Magnetron and Hydra, is it required to use 1/8 watt resistors? Or can I use regular 1/4 watt and just stand them up on end?
It is especially a PITA if you have to post pics in the Troubleshooting forum because vertical resistors are near impossible to read in the photos. But you'll do a good job and it will work the first time you power it up.
Churning through the Magnetron build. It's tight, so I'm standing up the resistors.
Does it matter if they're standing straight up 90º, or if they're at 45º? When I stand them up, I am pinching the excess lead toward the resistor—i.e. rather than a straight angle, the leads form an L-shape. Hope that's ok.
Avoid sharp bends right next to the resistor body. A gentle U-curve is best and start your bend 1 or 2 mm away from the body.
Next time, get smaller resistors. It's not about the wattage, it's about the body length. I have 1/4W resistors from DigiKey that fit and 1/4W resistors from Tayda that don't.
