2.54mm spacing fo +AK- pads?
jwin615
@Robert Hope this is the right forum
Any chance you'd consider using standard 2.54mm spacing on the in out led pads as standard procedure?
They seem to span 10.16mm overall but the led spacing is closer to 3mm.
LEDs aren't flush mounted, so I doubt the extra .5mm is all that beneficial on the builders end.
This is a totally vain request but for good reason.
Was hoping to get a working prototype together first before sharing but... I'm putting together a testing jig that uses pogo pin clamps. It can be built for only a few dollars and allows you to throw a populated board in it in seconds. No need for jumper wires and what not.
One clamp for the IO, one for the footswitch and you're jamming(or punching the workbench).
Would be great if it could interface with those pads but as it stands, it won't.
Thanks for your consideration.
Like these:
