that’s gonna be tricky to drill correctly isn’t it?Hex standoffs. You can either mount it to the enclosure with screws, or if you'd prefer a flush exterior with no mounting hardware you can float it between two sets like this:
(Different PCB, same concept)
these links are for 12V output ?
I was planning on getting these since they provide more ma (says 333ma) and are in stock. In a previous thread you mentioned using the 12v version (305s12). Since I'm looking for 9v operation I'm assuming these are what I'd need with the l78l05cv?
oh.dropped the regulators in the first version to lower the idle current consumption, but will probably bring them back for more stable voltage outputs. LDOs might not be a bad choice in that case.
Ooooh I haven't even thought about that! Finally a use for that portJust seeing this now and I’m super excited because it sounds like I’ll be able to power this from the AC port of my CS12 and get four more isolated DC outputs… awesome
i’m from australia too.Any chance PedalPCB is planning to stock those DC/DC converters for the USB Pedal Power board? Theyre not at Tayda, and I dont really want to have to make a single order from Mouser for one part - I'm in Australia as well so would rather buy from PPCB once - order some other stuff I want and not have to make orders with different companies.
I’m in the same boat. I need 4 400-500ma supplies with being 12v for the Madbean Archibald. It doesn’t have to be 12v but seem to sound better to my ears. I’ve been looking at power supplies all week. Cheapest option seemed the voodoo labs digital which has 4 500ma outputs I believe.Also, with the amount of C2CE builds around here I'd bet I'm not the only person interested in a diy "Mr. Universe" type high draw >500mA 9v isolator even if it's just a single channel. As always, moar is moar when it comes to power supply needs.
I’m little confused as to what these are exactly. https://www.joyoaudio.com/product/95.html
You want me to open mine up and post some pics?Let me check, I think I have one of those cracked open here somewhere.
