Guardians of the analog
- Build Rating
- 4.00 star(s)
There aren't as many options for bass overdrive pedals made specifically for bass. I see even less build reports for these projects. I am in the process of making a dedicated bass pedalboard so I wanted an overdrive that gave me more tonal options than the DAM Ezekiel clone I've been using the past couple years. Being on a boss kick (fanboi here) I decided to try the God City Instruments N.E.W bass overdrive that is a clone of the dunwich bass overdrive, and that is a feature rich expanded clone of the polarizing Boss ODB-3 bass overdrive.
I've watched a lot of videos on the ODB-3 and I agree with many of the complaints of the pedal. One, it's too boxy sounding, and the blend knob isn't the best. The LED clipping gives it more of a crunchy fuzzy drive versus overdrive. This pedal has many additional tone shaping knobs and switches. I like having a seperate level for clean and drive level sperate from the blend knob. This along with the silicon clipping option creates so many shades of dirt. The added mids tone controls make the pedal truly bass friendly. I opted to eliminate the center tone bypass switch as I didn't feel it was worth including. Not all mods are as impactful as others.
The build made me truly appreciate @Robert as the layout was kind of a . The drill template was less than ideal, the lack of documentation about what switches were used and the off board wiring pads were in the least ideal spots. I ended up using a on-on switch for the mids because I didn't learn until after the fact the it's an on-off-on and I had it boxed already. In spite of all this it is still a worth while build that sounds great.
For the enclosure I used the a matte black tayda box and UV print. I wanted to have a kind of 80s vibe to the look and went with a color scheme that matched that. I went with rocket and his 89P13 designation from the GOTG vol3 film because one, its badass and two, because I wanted something that had the odb-3 vibe name wise . For the demo I looped something simple and turned the knobs to give a sense of the wide range of sounds available, and let's be real...I'm a guitar player pretending to play bass . If you want a good bass drive then I can recommend this one. 4 stars for the drill template, off board wiring and build documentation short comings.
