ferdinandstrat
I've noticed that there arent many existing pedals that can remove the attack as well as the POG2, and I dont want to buy one just for that. Is it possible to make such a thing?
Cool vid. Interesting that the guitarist is using the POG and a compressor. It would be interesting to see what the POG2 is doing when the attack is dialed down. Most effects like the Slow Gear only work on the front part of a new sound, which is why it shuts down the picked part. But then you have to stop the sound to reset the gate that opens slowly. It requires a bit of practice to use them to give you a good bowed effect. Compressors just remove the dynamic range from the sound wave, and in combination with a boost give you a very long sustained sound.
Have you tried a Slow Gear? Does it have an adjustment for the attack? My guess is that most people keep the attack dialed way down on that effect to get the bowed sound, but you should be able to set it to open faster too.
Other than that I would experiment with a good compressor that used an opto-coupler. If you squish it enough to wipe out your dynamic range it masks most of the attack for all of the playing, not just the part that would be tamped down by a variable noise gate.
a maxed out compression pedal creates an impression that the volume from the guitar is nearly constant. very little perceived difference in volume hitting one string lightly or a full power chord. and in exchange for sacrificing dynamics you get a sound that seems to sustain for a very long time. a fuzz pedal does something very similar when it is mazed out except that the sound is also very distorted. I think the effect you want is probably a combination of a fast noise gate (do a google search for an old DIY pedal kit from PAIA named "The Gator") and an optical compression pedal, but most of the sound in that combination is probably due to the compression.
The gate on the gator is just a function of the size of the capacitor that is charged through the pot to open gate. So you could experiment with those factors. Again though, I think high compression is much more a factor in what you may be looking for. If you already have a Gator, build a compressor and give it a try, and try using both of them together.
The thing that I think is most limiting about the Gator and other gate effects is that they only work where there is an interruption in the sound that lets the capacitor discharge that is otherwise keeping the gate open. So you only get that effect when you mute the strings before playing something new. I don't think anything other than compression will affect the dynamics in something while it is being played, but perhaps the POG2 is doing something new, or something with a gate that is much quicker than the Gator. LMK if you find anything that provides details on how the POG2 works.
There is a DIY version of the EHX Attack Decay available if you want to build one. http://madbeanpedals.com/projects/_folders/FilterMod/pdf/RustBucket2019.pdf
Yeah it is not an easy build, but it is fun to play with when you are done, if it works. LOL
The hardest part really is the pots, and wiring them in. After that you are good.Hence why I opened this thread, seeing if a simpler alternative is possible with the FV1
