Abyss LDR selection
harrisxr650
Hello,
I'm about to start build an Abyss Vibe and since i have in stock some LDR i would like to know which will do the job nicely.
8k-20k-1M
or
16k-50k-2M
or
0-20Κ-1M
Any information is appreciated
Thanks
I used the LDRs indicated in the BOM and they work quite nicely. Just pick ones that match those specs closely. You may also take into consideration the wavelengths that the LDRs respond best to since you are using a yellow LED(550-590nm), it will make a difference in how responsive the LDRs are
How did your build turn out?
used the suggested LDR's from BOM.
2mm distance from yellow diffused led sounded best to my ears...
very nice vibe
