Aion Aperture (Ampeg Scrambler)
Could it be a head-room thing? Not enough headroom with the Valve Jr. to let the fuzz completely open up?…like you got Dikembe Mutumbo in the back of a VW Beetle…
I mean, the Marshall is toy essentially and only has one speed and zero headroom to speak of. Until 11:00 on the volume the Valve Jr. is essentially clean.
I’m not familiar with the amp (toy) but I’ve found that digital/solid state circuits (regardless of size/power) tend to have more headroom by nature. I’ve had an issue with fuzzes that sound very fuzzy and gnarly through a Blues Jr, but almost sterile through my big solid-state amp. I’ve also seen the opposite: some pedals shine with infinite headroom, other need a little help…
Reactions: fig
Maybe you're onto something. It could be why you carry an overall bad taste in your ears for Ge "real fuzz" Derek. To the ampmobile! Wait, does PedalPCB have an ampmobile?
I’m curious to know your opinion on the diodes Tim.
I know most of these measured at almost 0.8 v for Vf.
Reactions: fig
Seriously though Derek....I love my low-watter, but high gain pedals are not it's friend.
This is different though. I run a Big Muff, RAT, etc. full tilt through it.
It’s likely an error somewhere. I’ll go through and check everything again. The voltages seemed fine. I compare them to the GGG numbers and scaled them on a percentage basis with my Vnom and they were dead on.
Could also be bad transistors and/or diodes. NOS is awesome when it does what you want but sometimes…
I will have a functioning Scrambler. If I decide to do it over I’ll go Madbean this time and run of the mill semiconductors.
Reactions: fig
Big Muffs and Rats can handle a bit of heat. Maybe the Scrambler can’t? I know my Super Fuzz build sounds better through some dirt, and a bit sterile through high headroom. The Scrambler may need a lot of clean. Maybe I’ll build one and test it. How hard can it be?…
Certainly, If that meets your goal. No one would argue you've dealt with your share of issues with this one.
Big Muffs and Rats can handle a bit of heat. Maybe the Scrambler can’t? I know my Super Fuzz build sounds better through some dirt, and a bit sterile through high headroom. The Scrambler may need a log of clean. Maybe I’ll build one and test it. How hard can it be?…
I just did a comparison quick of my voltages and the GGG voltages in Excel:
Q2 and Q4 look like outliers and some of my voltages are almost 10% off of the GGG values.
