benny_profane
Did you mean that the spacing isn't the same for the stomp switch and the board pads? You can fill the hole with JB Weld and re-drill it. Since a toggle won't be under too much mechanical stress, the board connection should be sufficient. As the enclosure is already painted, try this:
- Mask off the hole with tape on the outside of the enclosure.
- Apply the JB Weld on the inside of the enclosure.
- Wait until cured.
- Sand the excess from the inside.
- Carefully mark the center.
- Carefully drill without excessive downward force.
