dawson
Somebody poisoned the Rabbit Hole!
Hello!
I'd like to show off my newest Big Muff build:
It's a MadBean Rabbit Hole built to the 'Triangle' spec's, and I've also added a 'Mids' switch that I pilfered from the Aion 'Halo' schematic and built on strip-board.
There are two 'Volume' knobs that can be toggled between with an additional footswitch- there is an LED next to each 'Volume' to always show which one is currently selected- red on top, yellow on bottom- the status LED assembly also toggles to match when the effect is engaged.
Here are a few shots of them guts:
So, why did I even build this thing?
I've been using a PedalPCB/BUGG FX 'Acid Rain' as my main fuzz-stortion tone, but in my particular rig it falls flat whenever I try to stack onto it boost for leads, BUT if I turn the volume knob from 6ish to full-blast, it does exactly what I need. I think I may have read somewhere that the 'Acid Rain' was derived from something 'Muff' adjacent, and even though I didn't have a 'Triangle' spec' around, it's my favorite-sounding EHX variant, so I figured I'd roll the dice and shoot the two out. Worst-case-scenario, I'll add a rad 'Muff' to the library.
I haven't shot them out with the band yet, but after comparing them side-by-side, I think it's safe to say that BUGG's circuit is absolutely its' own thing and I'm probably not going to be able to replace it so easily. I prefer the Triangle in certain single-note scenarios but the attack and note-definition the 'Acid Rain' brings to chords is really, really cool-sounding and more-usable to fill my current band duties.
In conclusion.. I'll probably be building another 'Acid Rain' or possibly a 'Raincoat' with foot-switchable volume control and set this build aside for when I need a more traditional 'Muff' sound.
The faceplate was designed in Photoshop modeling classic EHX style, then etched with ferric chloride. Brackets were designed in Fusion 360 and printed with carbon-fiber-infused PLA using my dinosaur 'ROBO' 3D printer.
A couple in-process photos:
If you're wondering WTF is wrong with this guy who thinks it's okay to build upside-down pedals with no pants on, this thread may answer a question or two:
SCHMORG
Thanks for reading!
Hello!
SCHMORG
Thanks for reading!
