p_wats
I remember a time when I used to build pedals that worked. In fact, this WAS one of those pedals! I built this double Arachnid last year and we used it heavily both live and while recording, but then the rotary control on the right in the image below failed (as confirmed way back in this thread).
I was able to get the defective switch out without issue and finally got a replacement. I popped it in last night and things seemed fine. I also added a toggle to access the internal programs (connecting ground at R5--the angle may make it look like it could be touching R2, but I assure you it's not) and again things seemed fine. However, after getting excited and trying it my usual rig I noticed a very loud hiss/noise that was not there before the repair.
What I've learned so far:
- The noise changes depending on the power supply (can get worse), but is still present with battery power
- The noise is NOT present in the circuit on the (inside) left---that circuit is as quiet as the FV-1 can be
- Using my audio probe I can verify the noise is not present as far as pin 2 of the TL074, but seems to come in at pin 1 and is affected by the volume pot
- I have changed the TL074, to no avail
- Thankfully, I've got a perfectly working Arachnid right next to it, so I have confirmed all voltages seem normal (4.5v on pins 1 & 2)
![double-arachnid_noise.jpg](https://dogisblue.com/images/pedals/double-arachnid_noise.jpg)
