This was my first test of the platform on new circuit. Circuit is not working, but neither is the bypass so it could also be the test platform.
It’s not a pedalpcb circuit so there is no ground at the top of the board.
I jumped the ground by connecting the ground at the bottom of the board with the power jack at the ground screw at the bottom of the test platform. I am assuming ground is ground and that along as it’s all connected that should work? Or am I shorting?
is there a way to test the platform?
I tried a jumper with no circuit between the in / out to see if bypass would work (again not sure If that is correct) but got no sound either
I am getting 9v at the power, the LED will light if If I ground it on the terminal, but not the board.
I also have 9v at Pin 8 on both op amps if I ground on the terminal, if any of that info helps.
