Likez2Jam
So at this point I'm not sure if I am connecting wires correctly as things aren't labeled on the pcb as the auditorium (pics below). especially with the switch wiring as the pcb is numbered, no sw/gr/in/out on this Kliche drive.
What I know:
1. when the auditorium is not plugged into power the signal passes through (yay I/O Jacks!)
2. when I plug it in there is a short ( I used a daisy chain for this and a tiny JOYO practice amp that I use for testing only) and when I plug in the platform to the power chain the amp turns off.
What I don't know:
1. What goes to ground?
2.Do all the switch lines go to sw?
3.can some be left unplugged for testing?
4. did I wire the dc jack to the board incorrectly? ( I used google pics to look at the enclosed pins and how that would be analogous to regular jack) maybe the dc jack won't work?
What I know:
What I don't know:
