Chuck D. Bones
Circuit Wizard
What Barry said.  Just look in the Troubleshooting forum to see how many times builders install the wrong parts.  And that's only the guys who'll admit it!
			I can drill all the holes with one bit and not have to constantly changethis is an awesome thread, really great info. is there any reason you promote using a step drill bit over standard jobbers, or even screw machine stubby bits?
Does that mean you use a small punch to create a spot to use the larger punch? that likely saves a bit of wear on your smaller punch..... I use two different size center punches to get it started.
Drugs are legal everywhere, except for illegal drugs that are only legal somewhere, does that even make sense?Oregon rules. Also legal drugs! Yay!![]()
It does if you're on drugs.Drugs are legal everywhere, except for illegal drugs that are only legal somewhere, does that even make sense?
You're missing out on cleaning up an even bigger flux residue mess. 95% of the time, the solder provides enough flux for my soldering jobs. The two instances where I use flux are when I'm desoldering with solder braid and when I'm pre-tinning a part that is reluctant to accept solder, like a pot shell or the leads on an old part. NB, flux does not preclude proper surface preparation on those parts, it just aids it.While reading this, it occurred to me I have never ever used flux (other than what's built into the solder), and I've not had issues. What am I missing out on by not using flux?
If your soldering technique is solid and you are happy with the results you are getting then flux is not necessary. This tutorial was intended for absolute beginners so if one is not confident in their abilities or is not utilizing an ideal setup of tools or ingredients, then flux is simply added insurance to create a solid connection. I think of Flux like using primer before painting. It's not necessary, but generally looks better in the end. It allows the solder to flow or "wet" more freely. Also, I think adding cleanup after using it is equally important.This is a great post. Picked up a few tricks (like I never thought about aligning and soldering the pots on the front of the enclosure instead of inside--I'm definitely going to try this on my next build).
