chongmagic
Where is the best place to find BA482 diodes?
Yeah I was wondering the same thingWhere is the best place to find BA482 diodes?
Did anyone actually ever purchase the BA482 diodes from qrpparts.com and verify they are a safe legitimate site...???? Anyone ???
I'm building the moonshine v2 from pedalpcb... Bootleg its called... and its designed for a switch on/on to switch between low gain and high gain... so these switching diodes BA482 are for soft clipping part of the circuit... I wonder if another diode could be used in its place... I know there's 2 different BA482 DIODES the ones you have are New Jersey Semi and the other one is made by Phillips... Do you happen to know what diode jhs is using now. Because the pedals still in production... The NE5532A Op Amp I had to get surface mount to get that exact op amp.. and coversion pcb... Do you know a source to get the NE5532A op amp through-hole..... ☺?
Tayda does not carry [it any longer. The NE5532A op amp doesn't even show up in there search I had to get the surface mount version and a pcb adapter from Cimarron Technology.
