sean2damax
Just finished wiring up a Bootleg OD and I’m getting crackle that sounds like a bad connection. I physically moved things and poked around but couldn’t find any loose components. Went through and reflowed anything that looked imperfect. Not sure where else to check next.
Im not sure if this is related, but the signal is also dropping out if I have the drive pot up, and it gets worse if I play harder. Comes back after a moment if I stop playing.
I swapped each one of the IC’s - no change.
Thanks for the help!
