Svenson007 Active member Mar 24, 2022 #1 Heyo! Just wondering if you can use a pedal pcb daughter-board when the pcb only has three pads. IN OUT GND. Do you just wire the SW (switch) to ground on 3pdt? SW is just another ground no? Thanks
BuddytheReow Moderator Mar 24, 2022 #2 I think SW just connects the ground for the LED. I could be wrong
Svenson007 Active member Mar 24, 2022 #3 BuddytheReow said: I think SW just connects the ground for the Click to expand... BuddytheReow said: I think SW just connects the ground for the LED. I could be wrong Click to expand... Think this is the case yes. So I’ll try two wires coming from ground on my three lug board IN/OUTGND to ground and switch on pedal pcb daughter board.
