And Ford missed out on the perfect marketing campaign by NOT hiring OJ to be in ads when they re-released the Bronco!!OJ was innocent!
I also saw the curvy traces on @KR Sound's boards and decided that I wanted some of that for me. I've also been seeing lots of super Rad Dizzy Elk builds, so I just sent this off to Shenzhen for fabrication. The board is designed for a specific set of transistors that sounded great on the breadboard (a pair of MP21E's in Q1 and Q2 and 3AX31C for Q3). No polarity protection on the board as that's being handled by the over-voltage and polarity protection circuit on my I/O breakout board. Looking forward to taking this for a spin!
One for Culture Jam's Duo-Vibe (https://www.madbeanpedals.com/forum/index.php?topic=23669.0) that I banged out at work today. Stole the wave control from effectslayouts' pcb. Made the response switch a pot for little reason other than I hate asymmetric controls and wanted to still use a 4 knob tayda enclosure. Figured worst case scenario I just end up hooking up a switch to the pads.
Been wanting to try fun arced traces for a while now and after seeing some of @KR Sound 's most recent boards figured I'd do teardrops as well! Solder mask hidden here to show off both of those
I'd be interested to hear your thoughts on the Pelota 2, it's one I've been meaning to play with. After diving into both BBD and FV-1 for delay I keep finding myself pulled back to PT2399, but I've never found a modulation setup on PT2399 that I was thrilled with.Pelota 2 - PT2399 delay
It’s my favourite PT2399. Modulation isn’t my thing, but having it around 10-20% depth adds a bit of flavour to things. Happy to share Gerbers if you want.I'd be interested to hear your thoughts on the Pelota 2, it's one I've been meaning to play with. After diving into both BBD and FV-1 for delay I keep finding myself pulled back to PT2399, but I've never found a modulation setup on PT2399 that I was thrilled with.
Good to know, and I appreciate it. I'll probably spin my own though, I don't have the patience for through-hole so I would do an SMD layout for pick-and-place. Maybe see if I can find room for a tube in thereIt’s my favourite PT2399. Modulation isn’t my thing, but having it around 10-20% depth adds a bit of flavour to things. Happy to share Gerbers if you want.
I would stick to an existing pot spacing standard. The PPCB is great because it fits with Tayda pre-drilled enclosures.I keep thinking about the placement of the pots after a sleep on it. Might push them in just a bit so theyre not too close to the fringes.
I know from now on, wherever possible, I’ll be using the predrilled enclosures (even if I have to drill an extra hole or 2, its better than 6), after drilling out 2 dozen enclosures last weekend.I would stick to an existing pot spacing standard. The PPCB is great because it fits with Tayda pre-drilled enclosures.
I would, but unless they just added it, they don't do 1590B3I would stick to an existing pot spacing standard. The PPCB is great because it fits with Tayda pre-drilled enclosures.
Never heard about this box size, looks interesting.I would, but unless they just added it, they don't do 1590B3
That's what I'm experimenting with in this layout
My main reason for doing it is keeping all the drill templates the same.I would, but unless they just added it, they don't do 1590B3
@Feral Feline mentioned it in another thread and it's definitely got potential, so I'm going to experiment with it.Never heard about this box size, looks interesting.![]()
an Enigma machineAnyone know how they come up with the numbers? And letters too?
Not quite as wide as a BB but about as tall as an N1 (125B). I swear I had a comparison image on-hand…
Diverging slightly, but here's a series of reference images of the 1590 series (we typically use) from the engineering models. @Smrtokvitek
No one makes a cheap knockoff?I can't fathom why the Q isn't a more popular size in DIY pedal-building.
