PCB Pins FTW!And one more which was sitting around for weeks now. A dual 3PDT footswitch with 3PDT order switch. Made for 1590BB portrait.
Did you know that 3PDT toggle switches have different pin spacings than 3PDT footswitches? Not that it could be confusing or annoying to find out the hard way..
I've started something similar. I should just finish the choreBecause I am a psychopath and was annoyed by my schematics not lining up nicely all the time, I went through my component library and standardized all the component sizing:
Boss Hyper Fuzz
2nd guess MZ-2
Wait, only 1 IC, so ... BluesDriver?
What relay are you using for this? I've been using the FTR-B4CB4.5Z for my relay boards, but it's a through hole device. I'm interested in switching to something surface mounted, and JLCPCB doesn't stock a surface mount version like the FTR-B4GB4.5Z or FTR-B4SB4.5Z.@PedalBuilder really got me interested in his smart IO board so I rigged up my own:
Harder to make this work with basic parts from JLCPCB, so the cost is higher than Chuck's basic relay, but the cost is worth the convenience.
Still waiting to verify, but if I did it right (and I often don't) then this should work with 1590B.
The SMD version: https://jlcpcb.com/parts/componentSearch?searchTxt=C126744x
Interestingly enough a little while ago at my day job I was pulled into a design review and the layout had been done in DipTrace. At my old job we used Altium Designer exclusively (and that's what I use for my stuff), at my current job we use Cadence Allegro and OrCAD, but this group had a simple non-production project and got permission to use DipTrace.I’m sure real PCB designers have moved on to other things like KiCAD and Eagle but DipTrace is what I’ve learned on and it’s what I’m sticking with.
It looks great! And from your description it sounds like it runs fine without the 100µF cap from 5v to ground, which makes me feel better about omitting it from future iterations.I got my layout of your smart IO in and verified. It's a nice little package. I have to play with components to remove extended parts (4x at present), but I'm pretty happy with it. Programming with UPDI is so much easier, just add a RPi, a 1k resistor, and you're set! Even 1590B friendly!
I'm feeling the peer pressureThe SMD version: https://jlcpcb.com/parts/componentSearch?searchTxt=C126744
B3GA4.5Z
B3G and B4G are the same in different dimensions.
