Buffer with the Octarock Octave
Ctrl4Smilerz
I'm really excited to build the Octarock, and am going to start planning a big parts order for my next few projects. I'd like to put a buffer where I'm planning the Octarock in my signal chain, and want to know, if I build the Kliche buffer or C-Buffer into the Octarock will it negatively impact the tracking or the sound in any way. Is the Octarock the type of pedal that is impacted by impedance?
A buffer should have no negative impact. In fact, the first stage of the Octarock is a JFET buffer. :)
Awesome thanks. So would a buffer do anything, or will the included one act similar to a C-buffer or Kliche buffer? Really look forward to this build! You've really been knocking out new pedals at quite the pace. Lots to look forward to.
If the two buffers are of good quality, stacking two into each other shouldn't be a problem. Noting that the Octarock is built for true-bypass, meaning the input buffer will only kick in when the effect is turned on.
