Build docs for Sproing Deluxe Reverb
I see several post about the
Sproing Deluxe Reverb, but on the website it says build documentation coming soon....​
Am I missing something? Or can some one post the build documentation?
Thanks for any help.
The completed doc hasn't been posted yet, in the meantime...
Parts list is here:
Drill template is here:
The wiring is fairly straightforward:
Input/Output jacks connect to the IN/OUT pads at the top of the PCB
9V / GND connect to the +/- pads at the top of the PCB
The two 3PDT breakout boards are pin-for-pin direct connections to the pads at the bottom of the PCB
The only "gotcha" on this one is the two 9mm potentiometers.
Parts list is here:
Thank you so much!
What printer settings am I supposed to use for this? I printed one out and the spacing between the pot/lug centers on the board doesn't match up with the spacing on the template...
Default. Full page. Check that it isn’t set to a previous scaled job.
Chasing my tail here. One pedal lights up but there's no trem or reverb.. The one I built tonight has GREAT trem effects but no verb!
