I was planning on building a captain bit for a bass playing buddy and thought I should probably add a blend knob. I was looking at the schematic and noticed 4 of the knobs look like they’re already blending in the effect. If I’m correct there, does this make a blend knob totally redundant?
The controls for this effect are pretty interesting, but none of them are a true "blend" of your clean signal with the effected signal.
Here's how it works.
If the "Base" knob is all the way down, and you have the Sub, Down, and Up knobs down you'll just have silence.
As you roll up the Sub, Down, or Up knobs it will roll in the octave fuzz effect for that octave without your original guitar/bass signal present.
As you roll the "Base" knob up it will roll in your original guitar/bass (KIND of like a blend) but it will apply fuzz to that signal. So yes, you're right that there is a blend, but it's not a blend with your clean signal. It's a blend with your instrument through a fuzz, and you as you roll up the Sub, Down, or Up knob you are basically mixing in those octave bands.
If you have Sub, Down, and Up turned all the way down and just roll up the Base knob it'll just sound like your instrument through a fuzz circuit. So basically, the pedal is like a 4 channel mixer, with the 4 channels being your instrument through a fuzz, a sub octave, a down octave, and an up octave, and you mix those 4 knobs to taste.
It's not a true clean blend, but if you want that you can achieve it with a combo build with a board like this:
https://guitarpcb.com/product/buff-n-blend-add-a-blend-control-to-any-circuit/
