Chop shop 2M resistor substitute...
The Gator
Looking at the circuit, there are a couple of 2M resistors to ground off the input.
I did not pay close enough attention to the shopping list and missed these. I have some 2.2M, or I guess I could series some 1M if it needs to be that accurate.
I could use the opinions if those who are more knowledgeable than I.
Thank you...again
Gator
I routinely sub 2M2 in place of 2M. A 10% up or down is typically not a big deal except in a few key spots.
In this case, the idea was pretty much to keep a 1M input impedance despite having a resistor before and after the input cap (a common practice in pedals). The 33k is almost irrelevant, it's more of a "gate stopper" for the JFET.
Using 2M2 means a 1M1 input impedance, which won't make a difference. As for the R2/R3 voltage divider, you'll be going from a 0.14dB reduction to a 0.13dB reduction.
Ok. I could start another thread if the moderator believes I should, but I want to make sure I understand the biasing method for this new version of the chop shop circuit.
The sag pot turned all the way CCW (should make it lowest resistance reading) then measure from the provided pad on top of the trimmers. Measure from the pad to ground I assume. Fine tune each trimmer until 6 to 6.6v is achieved?
I did this and the pedal works. However turning up the sag pot just cuts the sou d out rather quickly. It was also very, very touchy to tune in the trimmers. It goes from .4V to 7.4V when I barely touch the trimmer
That’s exactly what I did and I was able to get each one right at 6V, but I had a lot of wiggle room. In fact, one was right on perfect to start, and the other took almost a half turn from starting at about 1v to get 6.
My Sag control has a lot of room to it- I’d say the full spectrum of the knob.
