DeadAirMD
Op Amp Contest: Clever Continuity Tester Tells You Where The Problem Is
A continuity tester, as found on most multimeters today, is a great tool for finding broken connections and short circuits. But once you’ve found a short, it’s up to you to figure out w…
hackaday.com
This guy was cool enough to develop this and share some build docs. He developed a tester that tells you what and where the issue is through sound as opposed to just using a probe and tracing the entire circuit, saving a ton of time trying to figure out where the issue is. I built a testing box last month and this would be a great addition. Figured since we are all builders, some of us would find this useful.
