D Danielkrygsman New member Jul 25, 2020 #1 https://docs.pedalpcb.com/project/DuoPhase.pdf Based off this BOM how does the yellow Led and ldr set up work do u tilt the ldr’s so they face the led or something like that? Thanks
Many__Of__Horror Active member Jul 25, 2020 #2 I think there are some in the build reports that should show pictures.
B benny_profane Well-known member Jul 25, 2020 #3 You can do either. In either case, make light shields so that the two optical sections are isolated from each other. It doesn’t need to be anything fancy (e.g., you could use potentiometer covers), but light bleed should be prevented.
