Fizz
I am breadboarding my Odd One Out pedal before I solder the PCB and realized I am not sure how to wire lugs 2 & 3 on the B1M Drive Pot. Do both 2 & 3 go to the same connection or do I just connect one and leave the other disconnected?
Also, since this board already has its power conditioned do you all just make a voltage divider on your breadboard to bring 9 volts down to 4.5 VR? Or do you build out the power supply as on the schematic?
One last one. Since the board is powered on when you turn it on, how to you breadboard your LED so it only comes on when you switch from Bypass to Effect? I guess it is not necessary to do this but I thought it would be cool to understand it.
It took me two tries but I got it to work and sounds great. No noise at all as I thought there would be because of all the wires everywhere.
