SOLVED Danae - Dropped it
CheapSuitG
So yeah……..dropped my Danae and now it’s not working.
Passes audio on bypass, lights up, power to the IC.
Thoughts on what it could be?
Ahh ok, I thought it might be.
If you haven't already, pull out the opamp and reinstall it just to be sure.
Do you hear anything at all when you turn the pots back and forth?
What about if you unplug / reapply power with the pedal active? Any pops, chirps, etc?
Reseated the op amp, nothing
Nothing when I turn the knobs
Pops if I have the pedal on and plug it in, nothing from the pots.
Son of a gun! I thought I might have had my first solve. I'd probably check to see if either there is a cold solder joint that got knocked loose when it fell, or if one of the wires coming out of the break out board to the board got knocked together in a way that are causing the to short together.
Sorry to rob you of your first solve! It is a solid guess with the terrible photo I posted!
