Any other notable differences you can share? I had seen something from danelectro stating that the stock mode was a stock FTM circuit, so I’d be interested to know what else differs— all I know is that an 18nf c9 got the tone response the same as the 3699 demos (and that it’s a somewhat common mod value in some other site’s documentation), so the stock 3nf with a 15nf on a switch in parallel would make up the stock/mid boost mode. The octave switch being a footswitch is obvious enough, so any other changes would make it differ from stock (unless there are other FTM circuit revisions I’m not aware of that the 3699 was based on rather than the most commonly documented revision).
